Price for a new gimble ring
Goto JRMARINE.com. It will answer every question you have. They have a templete you can use to cut and get to your swivel pin. I just completed this job and it was super easy. The gimbal ring is whats going to cost. If its not cracked, JR Marine can fix it like new again. Give those guys a call, super good people.
If you have the rigging to get your motor out ,,hoist ,lift, whatever .......it's a nicer ,cleaner ...un butchered job....Those plastic pipe plugs on the top of gimbal housing just look like hell to me .........obviously my opinion......most I see aren't taped straight
Pulling most boat motors is a piece of cake .
Unfortunately I don't have acess to a hoist. I wax my outdrive to keep it looking new so the idea of having holes drilled bothers me. It really comes down to cost. If I tell my dealer to pull the motor they will. I don't know how much extra that would be.
Lou
Lou
I had mine done and didn't want the hole or holes. Once I factored in all the "extras" as already mentioned in this thread I had both transom assemblies replaced.....comes with everything. I think the assemblies were 2k ish each, where just the gimbal was 925 I think.
I just did a transom assembly replacement on my Scarab. I did not need to move the engine to get the outer assembly off. It would have been much easier with the engine out, but where the boat is being stored, there was no easy way to get the engine out.
Replacing the inner was a different story. I used some Detroit engineering and a sissor jack from my SVT Focus to jack the engine up enough to remove the inner bracket. I used blocks of wood to support the engine while I was working in and around the engine. A big PIA but it's done.
Jeff
Jeff
I did a variation of the JR route and here's the finished product. My cover plate is 1/8" or 3/16" aluminum and cutout to the same size as a new decal. I also did not want the plastic plugs Mercury sells, and I also didn't want it to look like it was ever done from the outside. From a short distance or untrained eye, you'd never know.
