Drive wont back on >
Drive wont back on
Drive wont back on
Old 05-10-2013 | 02:44 AM
Thanks for the replys , i new it wasnt the seals as i have a spare upper with no seals on the shaft and that woulnt go in , plus i could tell it was something solid stoping it going in the last inch .
paul buckner is offline
Old 05-11-2013 | 10:24 PM
i kinda have the same problem Installed complete new transom assy went to install engines with gil offshore mounts and one engine lines up perfect and the other is not. not sure what could have changed.
flat rate is offline
Old 05-14-2013 | 02:50 PM
tomas_wallin's Avatar
Originally Posted by johnnyboatman
the o ring on the shaft can cause the same crap, makes it hard to slide back on.ive had the same thing happen and just to check pulled the o rings off the shaft and she went right on, so I put them back on and backed that sob into a wall they slid all the way on then.
Those o-rings are a b*tch sometimes!!!
tomas_wallin is offline
Old 05-15-2013 | 11:50 AM
1 MAIDEN AMERICA's Avatar
Have you ever tried to give a cat a bath? Well, Bravo's do the same thing when you try to put them behind some HP.
1 MAIDEN AMERICA is offline
Old 05-15-2013 | 09:11 PM
I just did some Bravo work too. Everything goes back ok until the last inch. LOL put the thing in gear, slap on a prop and turn the driveshaft, Universal) a bit, move the drive back in as you turn or nodge the driveshaft. The drive shaft teeth needs to align with the engine (female) groves. The reason it won't go back since the teeth are not the same alignment as you took them off. no biggie, just be gentle.
PARADOX is offline
Old 05-16-2013 | 02:54 AM
Yes that can sometimes be the case if you have not changed the Gimble /B , but if the Eyeball is off from what was in there when you removed drive that thing will never go back on no matter how hard you ram it in . The eyeball has to be lined up with the splines on the motor .
