Difference between bravo 1 with 1.50 gears and 1.65
Need some help , I need an outdrive and found a great deal on a bravo 1 with 1.65 , mine has 1.50 .can anybody tell me the real difference between the two I'm running a basically stock 454 , please any info would be great and I'm dying to get out on the water and bravo 1 's in decent shape been real scarce for a decent price .....
You can make it work with bigger pitch props to compensate for the gearing.or swap the gears.my dad had his b3's torch a set of gears, the dealer put the wrong gears back in and changed them again.don't recall the cost or labor time though.
A B1 with 1.50 ratio uses upper gear set with 32/27 teeth, the 1.65 uses 30/23 teeth. The lower gears are listed as the same for each drive.
I have never seen a set for the 1.65, so I can not comment on them for strength. The 1.36 upper gear set has a shorter tooth length on the driven gear. In that case making a 1.36 drive is best done swapping lower gears.
In this case with 1.65 there isn't a lower set that you can use. So what ever pro's or con's are associated with that ratio would be in the upper gear set.
A prop swap would be needed to match your rpm, just how that affects the boat might be better addressed by calling a good prop shop.
Hope that helps.
Dick
Hope that helps.
Dick
