-   -   625hp on bravo 1s ? anyone tried this (https://www.offshoreonly.com/forums/drives-lower-units/295998-625hp-bravo-1s-anyone-tried.html)
slickwilly382 05-08-2013 08:30 AM
looking for a little insite here just got some 540cui 625 hp motors for my 382 formula I have stock bravos 1s fresh rebuild this winter on both and I had the new gears cryod and shot piened. Is there any hope, even if i drive it easy ? could they last a season ?
CLA 05-08-2013 08:36 AM
I have close to 400 hours on my 625 ilmor/bravo 1/imco -2 lower setup. I run the **** out of it and no problems, in a cat. Don't be stupid and you will be fine.
park35 05-08-2013 09:11 AM
I have 540s on bravo 1 and going on my thrid season no problems......
Flyin-Bryan 05-08-2013 09:26 AM
Yup,it's all in the throttle.
Keith Atlanta 05-08-2013 09:49 AM
In the Throttle = Wide Fuken Open? Is there any other way?
The cryo will help (kind of). Unless you drop a tooth. Change the lube often. This isnt an oil thread thread but I never had luck with Amsoil Severe Gear or Royal Purple. I had less failures on Merc Hi Perf. Now, I am running NEO.
Good threads:
http://www.offshoreonly.com/forums/d...dle-750hp.html
http://www.offshoreonly.com/forums/g...-breakage.html
UrbanDisturbance 05-08-2013 10:40 AM
I had 605HP motors on my 11,500lb 1994 Cigarette Top Gun. That does not include 220 gallons of gas, people, ice chest, anchors, etc. I did not have any problems with them for 7 years. My bravo dirves was the old style with a 1 inch prop shaft. I had 5 blade Maximus props. The drives got hot and left a chalky residue, even running 3200rpms. I purchase Halo Max drives showers and it went away. I recommend getting them. Be easy on the throttle and you should be fine. If it is not broke, don't fix it......trust me. If you mess with it, it will cost you some major $$$$ and headaches.
thirdchildhood 05-08-2013 01:19 PM
So you are dropping in two 600+ hp engines so that you can go out and drive like a little old lady? It's not just holeshots that take out drives. If you get much air then you will break them. No one is perfect on the throttles. My Bravo 1X lasted 7 hours behind a 525, in a 22' boat. I get a lot of air. The XR has lasted over 3 seasons. I still get a lot of air.....
wannabe 05-08-2013 01:23 PM
You will be fine just take it easy on hole shots and make sure you get drive showers if you don't have them.
Wannabe
slickwilly382 05-08-2013 01:38 PM
thanks for the info guys, I have drive showers and I will take it a little easy this season, my plan is to get some xr for next year
POWERPLAY J 05-08-2013 01:47 PM
Five years since mine were freshened and I drive the piss out of it. You can buy a couple spares for the price of one XR
