Bravo drive trim wont go up under power >
Old 07-10-2013, 05:00 PM
johnnyboatman's Avatar
Default Bravo drive trim wont go up under power
Drives will go up and down, but when accelerating hard the drives will not pick up, at idle or on the trailer they will pickup over 600lbs but when getting down on the throttle they wont move, let off the gas hit the switch they move, get back on the gass they wont go up, they go down no prob.
johnnyboatman is offline
Old 07-10-2013, 05:25 PM
Lines reversed? Pumps are set with more pressure out. Or could be seals in the rams.
Unlimited jd is offline
Old 07-10-2013, 07:18 PM
seen it many times lines are prob on backwards up is down down is up .then they switch the wires around at the trim switch to correct the issue .
however the pumps have more push out i think its 3000 lbs but half that on trim in .
smokin' gun is offline
Old 07-11-2013, 09:51 PM
third time someone said lines are backwards so I will switch them. thanks fellows I was wondering if they could had got switched, the blue wire is up and green is down correct.
Old 07-11-2013, 09:55 PM
the sky is blue (up) the sea is green (down)
dsparis is offline
Old 07-11-2013, 10:01 PM
ok thanks
Old 07-18-2013, 07:55 AM
My last boat did the same thing when I got it and the lines were backwards. Swapped them and all was good.
cp5899 is online now
