NXT trans fluid change >
Old 04-22-2014 | 10:37 PM
Default NXT trans fluid change
Any tips on changing changing the oil in a NXT transmission in 2007 formula 382?
the drain hoses are very acessable, but I can barley touch the dip sticks with my finger tips.
Can't touch or see the fill plugs.
Drain and fill thru the drain hoses?
Jeff H
Jeff H is offline
Old 04-23-2014 | 12:10 PM
Yes, it works very well to pump the oil out from the hose and then fill from the hose.
Falcon is online now
Old 04-24-2014 | 08:42 PM
Thank you, it worked.
Jeff
Jeff H is offline
