c72 transmissions?s >
c72 transmissions?s
c72 transmissions?s
Old 04-30-2014 | 03:01 PM
bcfountain's Avatar
Registered User
Default c72 transmissions?s
I have a older fountain 10meter.it has trs/borg warrner trasmissions my question.why does the port side trans still turn the prop on the drive even when in the rite position?i noticed when I had the motors where out that it looks like the port side trans had been into at one time.....[you can see where atv sealent had been used on the front cover]..also the trans is harder to turn compared to the starboard side.i was told that the trans was shimed too tight when rebuilt.would this account for the port motor using more gas and about 300 rpm less than the starboard side.the port uses about 8-12 gal more than the starboard side.or is the trans getting ready to take a dump?thanks all
bcfountain is offline
Old 04-30-2014 | 06:02 PM
Sounds too tite....as u suspect
Lil red knows a ton about em.....give him a shout....
commandersander is offline
