Bravo 1 Lower swap ? >
Old 05-08-2014 | 04:38 PM
Default Bravo 1 Lower swap ?
Got a Bravo 1X 1,36 year 2009 and want to swap lower with a 1,50 lower I got from 1999 not a x does it work? Thanks
502 Magnum is offline
Old 05-09-2014 | 03:45 AM
Any help please,thanks.
Bjorn.
Old 05-09-2014 | 03:06 PM
kaama82's Avatar
Yes. it will bolt right up.
kaama82 is offline
Old 05-09-2014 | 04:38 PM
Thanks Kaama,I did think it wold bolt on,but do you know if it can take the same power as the X lower drive,
Old 05-09-2014 | 04:55 PM
It's the uppers that always break.
thirdchildhood is offline
Old 05-10-2014 | 01:15 AM
Lowers are the same on regular Bravo and X drives.
http://www.go-fast.com/mercruiser_bravo_sterndrives.htm
Griff is offline
Old 05-10-2014 | 09:32 AM
Thanks guys,I will inspect the 1,50 before I use it,its for a 27 Rib with a EFI 500,I dont like the idea of using the 1,36 and go down on pitc on the prop,I did use a 1,50 with a 26P Bravo prop last year and it was Ok,this drive is worn out,and I got a x drive 1,36 and a spear 1,50 lower to use.
Bjorn.
Old 05-10-2014 | 01:55 PM
there are a couple places on web to check gear ratios, but i am pretty sure 1.36 and 1.5 take same upper gears. some of higher ratio drives use diff upper gear tooth counts.
dereknkathy is offline
Old 05-12-2014 | 01:48 AM
The ratio is controlled by the upper gear set in Bravo 1's X's and XZ's. The lower gear sets are the same.
http://www.mercruiserparts.com/Show_...O+I%2FII%2FIII
http://www.mercruiserparts.com/Show_...%2FII%2FIII%29
XR's use the same upper gear set and use the lower to control ratios.
http://www.mercruiserparts.com/Show_...28XR+And+XZ%29
Griff is offline
Old 05-12-2014 | 04:49 PM
Ok,so now we are sure the gear difference are in the upper gear,so its no use to change the lower.
What pitch to use with my 1,36 drive when I used a 26 Bravo with my 1,50 drive ? Can I make it with a 24 P ?
Thanks.
