Clunk after reverse >
Clunk after reverse
Clunk after reverse
Old 08-24-2014 | 09:29 PM
Default Clunk after reverse
2005 baja islander 496 bravo one drive . Dropped someone off at the dock today and backed away from the dock in reverse move shifter to neutral then forward and cluck. Not knowing what it is I went back to neutral reverse neutral fwd and cluck. Got the boat on the trailer and checked out the drive and with the drive at mid trim I can pull the drive up all the way to where the trim rams are fully extended. Tried the same thing on a buddy's boat his doesn't move. Not sure if it's related but I have noticed the down trim is slow unless The boat is underway forward. Sounds like reverse lock out problem but everything I can find talks about older boats. So I'm looking for help , where is he reverse lockout on my boat ? Can I fix the valve if it's stuck or does it need replaced? Thanks
Bajadreamin is offline
Old 08-25-2014 | 10:16 AM
Starting to answer my own question, found that the newer pumps have internal valving that controls the trim when in reverse. Looks like there is a kit to rebuild the pump 18545a1 it can be found online at alot of marine parts stores. Around 80-100$. Still hoping someone has done this to tell me I'm on the right path.
