Bravo 1 trim limit? >
Bravo 1 trim limit?
Bravo 1 trim limit?
Old 10-01-2014 | 09:10 AM
Default Bravo 1 trim limit?
Hello,
I had the boat out for a few hours this past weekend. It's really the first time under my ownership that I ran it up to good speeds.
I came across 2 issues, but the one I'm looking for answers today is about my trim capabilities.
So its a 24 Python with 454 Mag and Bravo 1 drive. I can raise it and lower it just fine, even all the way up when loading on the trailer or idling.
The main issue I noticed is under power. Is there a trim limit (safety feature)? I can only get the trim up to 3/4 down on the gauge when moving, and that's it. Again, Im new to this boat and performance boating in general and wanted to see if I actually have an issue or if it ssuppossed to do that.
AWOL is offline
Old 10-01-2014 | 09:23 AM
Does it just not want to trim up once your on plane?? If so the lines on the pump are probably backwards..been there, done that....
phragle is offline
Old 10-01-2014 | 09:28 AM
That's probably the best way to describe it. How can one tell if lines are backwards?
Thanks,
AWOL is offline
Old 10-01-2014 | 10:04 AM
switch them and try, wont hurt anything.
phragle is offline
Old 10-01-2014 | 10:34 PM
Yes, in answer to your question there can be a trim limit switch. Do you have separate trim and trailer/tilt buttons? If you do, you have a trim limit switch.
Cole2534 is offline
Old 10-02-2014 | 07:39 AM
Yes, I have two separate trim and trailer switches. Can this limiter be adjusted?
AWOL is offline
