Bravo One leaking oil into the hull >
Old 10-20-2014 | 11:26 AM
Default Bravo One leaking oil into the hull
I have a 232 Baja islander with a 6.2\Bravo one. It has the lower unit oil reservoir on the top of the motor by the belts. Somewhere it is leaking oil and it is ending up in the hull. I traced the hose all the way back to the transom and it is clean all the way back. I can't really see back there because it is so busy where the hose leads into the fitting, but I run my hand around there and it is clean. Has anybody experienced this? Where could it be leaking? It's frustrating. And it doesn't matter if it is running or not. It will leak just sitting there...and it is inconsistent oh how much it will leak too.
Thanks!
Abs777 is offline
Old 10-20-2014 | 11:40 AM
obnoxus's Avatar
Charter Member #1171
Probably the seal on the drive,,,,, pull the drive and see if the bellows is full of oil
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-22-2014 | 12:20 PM
if the bellows has oil inside it is the drive shaft oil seal , its not a big deal to replace it.,but the drive must be removed.
253 is offline
Old 10-22-2014 | 04:32 PM
Vinny P's Avatar
I hate the winter!!
X3
Not a difficult job to repair, but you have to know what the procedure is or you can easily make things a lot worse.
Vinny P is offline
Old 10-22-2014 | 04:35 PM
Biggus's Avatar
Usually, when mine starts to puke oil from the input seal, it's from too much metal in the lube and the gears are going south....
Biggus is offline
Old 10-22-2014 | 04:46 PM
BUP
or from corrosion that kills the input shaft seal. Also if corrosion has taken place and it only has to be lightly - it can pit the shaft area where the seal rides on. This will leak regardless even if you put a new seal in. It only talks a small amount of pitting or roughness or wear for the seal not to seal properly.
BUP is offline
Old 10-23-2014 | 06:12 AM
Mr Gadgets's Avatar
Charter Member #601
You can install a sleeve over the yoke where the seal rides and repair that pitting or excessive wear on the shaft.
Abs,
I would pull the drive and take a look if there is any oil in the bellows. Then go from there.
Mr Gadgets is offline
