Tapping case for drive shower
I thought I saw a drive that the billet cap/shower that was plumbed into the side of the drive...Was I mistaken and if not does it work or affect anything?? My last boat I had my intercooler water plumbed to my cap. This boat doesn't have that option...
Ok I have a Stupid question I have been considering adding a drive shower to my twin bravo set up. But at what point would you guys say it is a necessity? I have looked at the ones from The SIMREK Corporation that say they require no drilling of the drive. Has anyone ever heard or used this type. Thanks for the feedback!!!
This setup could work with a one way valve screwed into the side outlet, without the need of external or through hull pickup. Without an anti siphon/one way valve, water supply to the seawater pump would be aerated if the drive cap is exposed above waterline.Bravo drives with low water pickups may overcome this problem with higher water pressures induced by high speeds.My friend's Fountain has the Imco extreme drives that has the shower drive to the cap in a similar fashion as in the picture, albeit the line exits in behind the drive not the side, water fed from the lower unit.
http://imcomarine.com/cal_store/driv.../sc-drive.html
http://www.diamondperformanceparts.c...roductid=16817
Good points . I didnot think about the siphoning effect. I'm actually thinking a transom pickup, then Y it off to both drives. The boat I have now is good for long distance runs and I know that is cooking the oil. I use a great additive which works great but want to put those billet caps with the shower on this one also.
