bravo one gear lub? >
bravo one gear lub?
bravo one gear lub?
Old 04-08-2015 | 04:57 PM
Thats what I was thinking of doing. Leave the top off the reservoir and pump it from the bottom all the way up into the reservoir that would push any air out the top u would think. It would be more pumping but it would be worth it to not take every thing apart.
1989mach1 is offline
Old 04-08-2015 | 05:58 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Always removed the top plug, mostly for drain venting, then filled from bottom till came out top, reinstalled top plug, then pumped a couple more pumps till lube started coming in the bottle to purge the air out of the hose, then just topped off bottle from inside.
I'd think if you leave the top plug in, you'd just have a little more resistance as your now venting thru the bell housing/upper housing check ball and resorvoir hose with smaller openings than the open top hole, so possibly just gotta pump slower.
US1 Fountain is offline
Old 04-14-2015 | 09:35 PM
I left steering on ansd just pulled the bottom plug and rez cap and let drain over night then pumped up till it filled the rez to the full line and worked out good.
Old 04-14-2015 | 09:39 PM
[IMG][/IMG]
Old 04-15-2015 | 01:36 AM
Originally Posted by 1989mach1
Ok guys I know when changing the lube u pump fro the bottom till it comes out the top hole then put tbe plugs back in and fill the reservoir. Now on my new boat the top plug is behind the steering and tie bar mount and the only way to get to it is by removing the mount. Can u just pump from the bottom till it shows up in the reservoir and not have to take apart the steering?
Yes.
I have the same issue with my Marine Machine steering and have been doing it that way for 5+ years.
Make sure the caps are off the reservoirs when you pump lube into the drives.
Originally Posted by Sydwayz
What kind of steering is it? On the Marine Machine halo, there is a hole on the side where the vent is, where you can put a screwdriver in there.
Can you stick a right angle screwdriver in there and pull the plug out?
Mine do not have the hole on the '97 AT but did on my '96 Pantera. Same steering bracket except for the hole.
Griff is offline
Old 04-15-2015 | 04:55 AM
I use a screwdriver bit with a 1/4" wrench on it to loosen and tighten the upper plug. Once it's loose you can get enough grip with a screwdriver at an angle to remove it.
thirdchildhood is offline
Old 04-15-2015 | 05:30 AM
Just drain 1/2 a qt and top off the bottle....
Unlimited jd is offline
Old 04-15-2015 | 07:51 AM
Knot 4 Me's Avatar
Lol!!!
Knot 4 Me is offline
Old 04-15-2015 | 02:17 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
BE CAREFUL doing that. Sometimes it will continue expanding after you stop pumping and create a HUGE mess. Ask me how I know that. Stop at the "add" line on the bottle, and come back and top it off the next day.
Sydwayz is offline
Old 04-16-2015 | 07:33 AM
Originally Posted by BUP
And sometimes it will stick the float causing the alarm to stay on even when its full of gear oil. that's common to.
That drove me nuts.
Cole2534 is offline
