bravo one gear lub? >
bravo one gear lub?
bravo one gear lub?
Old 04-16-2015 | 07:52 AM
I have the same steering.... I use a right angle flat head to get mine off.
mptrimshop is offline
Old 04-16-2015 | 10:36 AM
I leave the top plug in and fill from the bottom up all the way to the reservoir.
Using a 5 gallon pail with a pail pump helps with less air bubbles from changing bottles.
Remove and clean the reservoir.
offshorexcursion is offline
Old 04-16-2015 | 11:11 AM
Plum_Crazy's Avatar
+1
I use this pressurized gear case filler. Makes it go pretty quick. The moment I see the oil start to enter the reservoir, I release the pressure.
Plum_Crazy is offline
