Stellings Extension boxes >
Old 07-12-2015 | 09:56 AM
fireboatpilot's Avatar
RIPSTA Racing Team
I sent them a contact question but haven't heard back yet. Thanks!
fireboatpilot is offline
Old 07-12-2015 | 01:13 PM
Originally Posted by fireboatpilot
Griff, do you have a pic of the water neck by chance?
Not sure if its exact or not, but looks pretty close.
http://www.mercruiserparts.com/Show_...GIMBAL+HOUSING
Griff is offline
Old 07-12-2015 | 08:17 PM
Yes Randy closed up about a year or two...long gone.
activator40 is offline
Old 07-12-2015 | 09:38 PM
RIPSTA Racing Team
Yea Griff, that would be the same bolt pattern for sure. I think I can work with that and for under $20. each I'm sure I can make it work, Very helpful. I know Randy closed up but like I said the number is still active for parts but getting a message thru was a little wonky. Randy must have sold the box design to Everett. Their even calling their boxes Stellings
Old 07-13-2015 | 07:22 AM
Have you talked to Everett? I am curious if they have it in stock. I hope they have all this stuff or can get it.
The pillow block with bearings was about $450 complete with bearings years ago. I think...
Keith Atlanta is offline
Old 07-13-2015 | 09:46 AM
RIPSTA Racing Team
Not yet, I'll probably use the Merc water necks and modify them if theres any clearance issues. The Stellings ones had a few more bends in them but I like to machine everything out to accept AN fittings and braided lines anyway. The bearings I just needed the numbers anyway. I can press them in and out myself. I did them awhile back but like a dumazz I tossed the old ones in a box and don't know which are which. Why would you need to replace the pillow block itself? Pretty much a solid unit to damage it enough to need replacing.
Old 07-13-2015 | 10:47 AM
Because when stellings sold them it was faster and almost the same price to just buy the whole assembly and ship it rather than screw with the bearings.
I keep a spare one. If you hear the bearings going, when necessary, you can just pop the carrier in, shim it, put the drive back on and you are back on the water in an hour.
Old 07-13-2015 | 03:12 PM
bor's Avatar
bor
Ok here we go ,took some pics of the bearings and waterneck of my stellings box
Hope this helps
bor is offline
Old 07-13-2015 | 10:04 PM
Your water neck is completely different from mine. Mine is just like the Merc one and uses the hose for the bends.
Griff is offline
Old 07-13-2015 | 10:21 PM
Originally Posted by Keith Atlanta
WTF!!!! That pillow block is $850 bucks!
thats what i was thinking
315duramax is offline
