-   -   Stellings Extension boxes (https://www.offshoreonly.com/forums/drives-lower-units/328150-stellings-extension-boxes.html)
fireboatpilot 07-31-2015 11:06 PM
Thanks Bor and griff. Looks like the Merc water neck will work. Bor, do you have the drive line set up with drive shafts or the set up using the long bravo shafts? I wonder if theres a difference in the bearings? Also are both bearings the same? I'm running it until the end of this season, just taking it easy. Winter project will be pull the drives for bellows, lower gear change to 1;36, paint and bearings.
bor 08-05-2015 01:36 PM
Fire ,
I have the drive line set up and look like the bearings are the same besides the one is a closed one and the other is open ball bearing but I don t have measured them .
Also looked at a merc bearing carrier I have for my driveline set up that have the same bearings in it ,one closed and one open .
hope this helps
Joe308 04-28-2022 10:58 AM
I know this is an older thread but I am also in need of the Stellings water necks. Anyone know if there is a NOS source for these or what path could be taken to replace with Merc parts? Thanks!
