Drive Too Low or OK? >
Old 09-23-2015 | 09:52 PM
Plum_Crazy's Avatar
Originally Posted by ICDEDPPL
I think if you put a spacer to match in the port side drive you`ll get even better results!
After the new paint, I could only afford one!
[ATTACH=CONFIG]545580[/ATTACH]
Plum_Crazy is offline
Old 09-24-2015 | 11:27 PM
F*uck it who needs a second spacer when you have paint like that! Nobody sees that $hit underwater anyway!
ICDEDPPL is online now
Old 09-25-2015 | 07:23 AM
hullofjustis's Avatar
Originally Posted by jrider
why not just ditch the boxes? Or go with neatrals? Seem like a ton of work to try to cool the drives. I dont see drive showers either, if they are properly cooled at speed, why would they need to be in the water at idle?
Just throwing it out there
1. The engines are sticking out the hatch
2. Center of gravity
3. Exhaust holes in transom had to have custom spacers made
4. The exhaust is to close the fiberglass so any wire or cable i am worried will melt over time
5. It is only my labor to pull the engines and boxes and hopefully the shop that set it up, will fix there f up!
There are drive showers on them now
sorry plum crazy did not mean to hijack your post. I meant to ask you does the boat handle any different with the drive down 2 inches?
hullofjustis is offline
Old 09-25-2015 | 09:58 AM
Plum_Crazy's Avatar
Planes easy now and feels hooked up at WOT.
I'm heading out this weekend to try some 4-blade Bravos. If they get on plane, they should be faster than anything so far. There's no way I would have considered them before the spacers.
Old 09-25-2015 | 10:57 AM
Originally Posted by plum_crazy
planes easy now and feels hooked up at wot.
I'm heading out this weekend to try some 4-blade bravos. If they get on plane, they should be faster than anything so far. There's no way i would have considered them before the spacers.
please let me know how yours reacts with 4 blades. I know the hulls are different but....
With the one inch spacer my results have been interesting
30 4 blade bravo's with the satin finish i run 84-85 at 6000 rpm and pops right on plane. My cruise 35-40 mph at 3500rpm
26 5 blade hydromotives consistently ran 84 -85 mph and one time 87mph at 6000 rpm but blows the props getting on plane unless ride the wake or play with the throttles. 50 mph at 3500 rpm and chine walks at wot
2 inch spacers
87mph 6000 rpm consistently better getting on plane but still blows out the props. I do not think i had the same amount of fuel and the temprature was definitley lower and less humitdity
this weekend i am trying the 4 blades for giggles.
Old 09-30-2015 | 09:18 PM
Plum_Crazy's Avatar
I got out today with some 28P Bravos. To my surprise, the boat jumped right on plane, the best of any prop I've tried. But, the pitch was too low. I hit the limiters and saw 5500 RPM with only neutral trim. Speed matched my best with the Herings and was still accelerating. 30P should do the trick.
Old 10-01-2015 | 07:03 AM
are the 28 pitch props yours? I have a set of 30 bravo 4 blades that ultimately I think I will need 28 pitched props. I could spin my 30's to 6000 rpm but I had a lot of slippage, like in the 20% range. I have not run the boat with the 2 inch spacer and the 30's only the 26 5blade hydromotive
Old 10-01-2015 | 11:38 AM
Plum_Crazy's Avatar
Not mine. I got them through the Bblades test program.
Old 10-01-2015 | 09:31 PM
Remember the cooler weather will result in faster speeds anyways....
Thanks for the updates!
offshorexcursion is offline
