Bravo III 2.0 Upper and Bravo I 1.5 Upper the same? >
Old 09-28-2015 | 03:26 PM
Default Bravo III 2.0 Upper and Bravo I 1.5 Upper the same?
I'm reading conflicting answers on whether a Bravo III 2.0 upper unit and a Bravo I 1.5 upper unit are the same. Can anyone clear up the confusion?
I have a Bravo III 2.0 upper on my boat. If I bolt up a Bravo I 1.50 lower unit to it, would it be identical to a complete Bravo I 1.50?
jstrahn is offline
Old 09-28-2015 | 04:21 PM
Yes both 27/32 upper gear set, make sure your lower is an oiler.
GLENAMY 242SS is offline
Old 09-28-2015 | 04:28 PM
I appreciate the response. How do you determine if the lower is an oiler or not?
jstrahn is offline
Old 09-28-2015 | 04:32 PM
When you look at the mating surface there will be 2 rubber "O" rings 1 about 2" dia. the other about 1/4" dia, a non-oiler will only have the larger O-ring.
Old 09-28-2015 | 04:33 PM
Also you will need to replace the decals to work properly
Old 09-28-2015 | 04:39 PM
Gotcha. Sounds like the non-oilers were the older lowers. Yes, I'm anal so I'll have to replace the decals to Bravo Is or it will drive me nuts. Thanks for the help.
jstrahn is offline
Old 09-28-2015 | 08:02 PM
Man I thought I was the only anal retentive person out there!!
all the best
3pointstar is offline
Old 09-28-2015 | 08:55 PM
I have a customer who has the same issue. His boat wont go past 50 mph he states. The upper says b3 and I don't know what lower he has. 1.36 or 1.5 . I'm used too the xr and don't know much on the b1. Any help would be appreciated.
Eliminatorshane is offline
Old 09-28-2015 | 09:29 PM
B 3 's came in different ratios accomplished by upper gears, should be stamped in side of case on decal. Difference between 1.36 and 1.5 is solely in upper 1.36 having 29/27 and 1.5 having 32/27 both lowers have 15/19 count gears.
Here is the chart I use click around and you can reference all Merc drives/
Hope this helps
