Trs upper With a Bravo Lower >
Old 02-18-2016 | 08:35 PM
  #51
Originally Posted by SlowRyd
Sorry for the late update but here it goes.... Took the boat out two weeks ago and so far the drive works great. Solved my handling issues and is already at least 5mph faster on my deal with a prop that is not quite right.... Now the bad news for me. On my last run to attempt to air it out and see how it does a stock rod broke in the engine. But no worries at this point all that I'm waiting on to get it back together is my new Callies crank and rods to get here Monday then a little head work and we'll be putting this thing back together with more power for testing.
Sorry to hear you had engine issues, but it sounds like you will have a strong bottom end with the upgraded rods and crank. Great news the outdrive held together and had a solid mph gain.
What RPM are you turning with he new drive compared to the TRS? Do you feel the drive gearing caused some of the issues?
I will be interested in hearing more when you are back testing.
Thanks for the update!
goin70 is offline
Old 02-19-2016 | 07:21 AM
  #52
That's the big issue right now for doing a twin conversion but I'm working at it. On my deal being a single and left steer I'm gonna switch to a left hand prop to make it drive forward in forward gear.
It's kinda screwed up that merc made the lowers different on the trs instead of the uppers as far as left and right goes.
Considering the left/right issue for twin set ups; could a #3 Speedmaster lower work as a better base to start with rather than the bravo lower?
carcrazy167 is offline
Old 02-19-2016 | 07:38 AM
  #53
Regardless I'm very excited about your project. I've been plagued by the deep TRS drives on my Scarab for far too long. Of all the options out there to gain a more aggressive X dimension for my set up, I am most interested in what you are putting together.
Old 02-19-2016 | 02:00 PM
  #54
Biggus's Avatar
Standard length Konrad 540 is 1.7" shorter than TRS, shorty Konrad lower another 1.7" shorter. Direct bolt on, zero mods.
Biggus is offline
Old 02-20-2016 | 04:04 PM
  #55
Biggus,
I understand why you have been a huge advocate for Konrad, no doubt they make a solid product. But even with their shorty lower, I would only be a total of (according to your post) 3.4 inches higher than my current TRS. If the bolt on product discussed on this tread can attain 4.75 inches shorter .... well it just makes me curious to wait and see what happens here.
Old 03-07-2016 | 01:34 PM
  #56
Sorry for the lack of updates but I'm waiting on getting my heads, intake and oil pan back from getting Teflon coated then we'lll be able to get the engine on the dyno and back in the boat for more testing. Probably going to be in the market for something along the lines of a 26p left hand bravo one prop if anyone has a deal on one
SlowRyd is offline
Old 03-07-2016 | 01:37 PM
  #57
I don't think the drive had anything to do with it. It was an engine that has been used and abused and tuned for kill! We were pounding on it trying to tear the drive up and were unsuccessful in doing that
SlowRyd is offline
Old 03-18-2016 | 05:41 AM
  #58
Any updates on this, super interested
TruxtonFox is offline
Old 03-21-2016 | 09:40 AM
  #59
Just about finished with the new power. Just finishing up changes to the water system and then time to dyno.
SlowRyd is offline
Old 03-21-2016 | 10:29 AM
  #60
