Drive Showers
Old 09-29-2016 | 07:59 AM
  #51
Just make sure you check the pick ups every once in a wile on all drive coolers. Took me hour to dig this tooth pick out. It was jammed up there 3+ inches
92nsx is offline
Old 09-29-2016 | 08:00 AM
  #52
I still plan to get one, just have a hard time justifying 200 for a piece of stainless tubing. The money isn't the issue, its just 200 for tubing.
AllDodge is offline
Old 09-29-2016 | 08:08 AM
  #53
VoodooRob's Avatar
Drop in the bucket for piece of mind and to keep your drive oil temps down. $200 = 60 gallons ,+ or -, of marine fuel.
VoodooRob is offline
Old 09-29-2016 | 08:13 AM
  #54
Agree, keep looking at the top cap ones also, but drilling a hole.
As before its not the money, just spent over 30K on my 20k boat
AllDodge is offline
Old 09-29-2016 | 10:41 AM
  #55
What do you do when you have a high X dimension? My pickup is high and dry on plane.
TxHawk is offline
Old 10-07-2016 | 05:16 PM
  #56
Gordo's Avatar
Charter Member #94
My Active Thunder has a pretty high X-dim,. and works great.
Abby-someone
Gordo is offline
Old 10-11-2016 | 12:03 AM
  #57
I think the water spinning off the prop will feed the intake for the shower. On my Eliminator, running a high X dimension, it has one that looks cut down and flush with the cavitation plate. I've read that is needed to reduce and cavitation, increase speed and still cools the drive.
2Slow4me is offline
Old 10-12-2016 | 11:04 AM
  #58
Here is a picture looking back. You can see the pickup at the top. I'll have to get a picture at speed, but it is barely getting sprayed.
TxHawk is offline
Old 10-12-2016 | 06:45 PM
  #59
I bet there are a lot of them providing false peace of mind ...
thirdchildhood is offline
Old 10-29-2016 | 09:35 PM
  #60
Registered User
Quick question for the brain trust. My new to me Formula 353 has XR drives and has never had drive shower on it. They came with the boat, just never installed. So before I drill the plates which side does the pickup go on? Since the props turn in opposite directions I would assume that the pickups are also on opposite sides. Question is on the Right hand rotation drive does the pickup go on the right or left. Assuming the left will be opposite.
Thanks,
Dave
Dkahnjob is offline
