Merc ship drives with oil in them? >
Old 02-02-2016 | 10:44 PM
BUP
Believe it or not the last 2 brand new bravo drives each one maybe had 8 oz of oil in them when shipped hence my answer as I thought for the change. This has been with in the last 6 months from ordering, I do not know if it was a mistake or a change or a possible shipping change. Sounds like a mistake after the fact.
I pressure tested them before the install and then filled with gear oil - both still running around. With that said I should have mentioned but more so make sure you check gear oil levels like others have said and the condition of the gear oil. I have been an OEM since 1991 and have been in the boat biz for over 30 years now.
Being a left over outdrive from Stingray Boats even with gear oil in it - I still would change it as merc recommends yearly gear oil changes anyways even if you do not use the boat plus I like to pressure test all drives anyways including new & remaned before the install.
BUP is offline
Old 02-03-2016 | 11:22 AM
Have not received the drive yet but the serial number is 2AO12659
DrewDown is offline
Old 02-03-2016 | 12:39 PM
If new drives need a break-in , how come manufacturers take brand new boats and run the **** out of em testing for top end numbers ?
HALLETT FAN is offline
Old 02-03-2016 | 01:27 PM
BUP
Here is the best I can do and if you ever took any Mercruiser factory training its talked about and listed in the manuals as well. Link backs up what i posted.
The same goes for the engine side - proper break in should be done - with that said how many people follow the proper procedure ?
Read link about 10 hour break in as Mercruiser list this the same way as well in some of their manuals. I believe this was a copied section and posted in this link.
http://www.bluewatermarinesvc.com/ht...uiser_fyi.html
BUP is offline
Old 02-04-2016 | 04:51 PM
Drive showed up full of oil and a little 16oz SAE90 to top it off. It has dual water pick ups. Last drive had just the side pick ups. Is that going to be an issue?
DrewDown is offline
