Merc ship drives with oil in them?
Merc is shipping you an 2013 outdrive - They do not have any leftovers that far back. Some 2015 left.
Anyways are you sure this is coming direct from Merc ?
Where are you buying this outdrive ?
When Merc ships drives - no gear oil is in them and yes there is a proper break in procedure and drive oil change. Merc does not use a special break in oil for new drives.
Can you explain proper break in/oil change or point me in the direction.
Can not speak for Stingray boats as to how and what they did with a leftover drive.
Anyways Merc recommends for brand new and replacements gears rebuilds a 10 hour break in period.
no full throttle starts
Do not exceed 75% of throttle during the 1st - 5 hours and for the next 5 hours only intermittent full throttle - Do not due extended full throttle running.
Do not operate at any constant speed for extended periods
The outdrive should be shifted into forward gear a min of 10 times during break in with run in time at moderate rpm after each shift.
gear oil change at 10 hours but IMO I think 2 hours and again at 5 or 6 hours of run in time. Just my opinion .
Oops!
All the new drives i have gotten from merc had gear lube in it,but of course needs to be checked break in is just common sense don't run the crap out of it for the first 10 or so hours change the oil 20 hrs or so sooner if you want,I have been a merc dealer for 20 plus years
When Merc ships drives - no gear oil is in them.
Good luck.
