B1's on ITS Boxes
Old 03-05-2016 | 07:26 AM
Default B1's on ITS Boxes
I bought some near new ITS boxes for my Formula and after the fact realize that merc doesn't make a long input shaft for the B1, only the X series drives. I have a practically new set of B1 Swept back uppers that I planned on using but at this point I don't see how that is going to happen. Does anyone have any suggestions other than selling the B1 uppers and replacing them with X uppers.
endeavour32 is offline
Old 03-05-2016 | 07:58 AM
I would think there would be a way to change the flange or the u joint to be able to run the long shaft on your upper.
indysupra is offline
Old 03-05-2016 | 08:06 AM
The XR input shafts use a larger u-joint and I believe the gear end shaft diameter is bigger. The only thing I can think of, is to turn down the short end of the XR input shaft so the B1 gears would fit on the x shaft. You can do this with XR propshafts (so you can run standard Bravo gears) but I don't know if you can do this with the gear end input shaft.
It seems to be a rather complicated project. In addition to the above, you also can't just install an X input shaft because the retainer ring, as I understand it, is larger than a B1 retainer ring. You also can install the B1 ring on an X shaft because the yoke is too large and the spanner wrench won't fit over it. My head is hurting with all of these small yet road blocking differences.
Old 03-05-2016 | 08:49 AM
The 336 formula for sale at shogren has bravos on imco extension boxes. How do they run those?
turbofox54 is offline
Old 03-05-2016 | 08:58 AM
Imco makes their own shaft, but its longer. The ITS boxes are only 7" whereas the Imco boxes are 12". The shafts are not interchangeable.
Old 03-05-2016 | 09:06 AM
So maybe shortening an imco shaft would be the easiest way to custom make a part?
Old 03-05-2016 | 09:09 AM
Thats a pretty expensive option. IMCO wants over $700 for just 1 shaft, then the machine work to make it fit.
Old 03-05-2016 | 09:14 AM
It's a boat...nothing is cheap lol. Prolly cheaper than the xr upper upgrade but you would also get strength of the xr too that way.
Old 03-05-2016 | 09:44 AM
There are joints out there that are 2x2. (2 different sizes per plane)
class6 is offline
Old 03-05-2016 | 10:14 AM
Mbam's Avatar
Offshoreonly Advertiser
You can do it by using an X gear set and the ITS u joint shaft.
Imco makes a retainer that will let you do that on the standard upper housing.
Mbam is offline
