Pre Alphas
Old 03-30-2016 | 07:51 AM
You stated that mine is an MC-1. not to be stupid (but I am truly ignorant as this is a new area to me) how do you know...better yet How would I know??
what are the earmarks?
Ayuh,... The top ring/ liftin' eye went away with the MC-1s,.....
R, MR, 'n Alpha 1 are flat topped drives,....
The MC-1 also has a rounded aft end anti-cavitation plate, where the later drives are more squareish,....
Bondo is offline
Old 03-30-2016 | 08:19 AM
I see. That Makes sense ... and Since the Boat is an 80 Model... I could safely assume the Drives are 79-81 and (parts) should interchange with most any unit out there...correct?
("'bout the mid/ late '70s, on, up to '91, All of 'em will interchange, either by the unit, ei; uppers interchange, or lowers interchange, or complete drives interchange, again up to '91, 'n the A1, Gen.IIs,.... ")
340mopar is offline
Old 03-30-2016 | 08:26 AM
do you know the spline count variances?
13, etc...
also .. should I find a solid case and the splines not match.. can the guts from one be swapped to the other without issue?
340mopar is offline
Old 03-30-2016 | 10:42 AM
Another thing to keep in mind if you are looking at used drives is gear ratio, there seems to be a ton of 1.94:1(4cyl) mc-1 out there, not many 1.5:1. I have a few 1:94 laying around if you need cases.
turbom700 is offline
Old 03-30-2016 | 10:46 AM
I am uncertain of my ratio., spine count etc.
I do need at least one case. what is your price?
340mopar is offline
Old 03-30-2016 | 11:32 AM
If its v8 its more then likely at 1:50 to one,
I'll get you some pics this weekend and we get figure out a price. Whats your email
Old 03-30-2016 | 11:35 AM
[email protected]
James
yes twin 350's
340mopar is offline
Old 03-30-2016 | 12:36 PM
Ayuh,..... Complete outdrives, will interchange from the late-'60s, through '90,....
13, etc...
The changes over the years were All internal, not all internals will swap to older, or newer cases,.....
Though, many of the parts, 'n pieces followed the entire line up,...
The lower unit input shaft splines changed in the early/ mid-'70s,....
It will swap outdrive for outdrive, but ya can't mix, 'n match uppers with lowers,.....
You can swap on a newer lower unit than yer's, up to the 1990 units, as in '91, the Gen.II came about, 'n swapability ended,....
There's some pictures down lower on this page to help,....
Lotsa Great info in there besides,...
Bondo is offline
Old 04-18-2016 | 11:40 AM
[email protected]
James
340mopar is offline
Old 04-18-2016 | 11:46 AM
I did pick up this Alpha One ...no clue as to the ratio (to be certain)
Owner said it was an 1989 small block V-8 Ratio: 1:84 , but I do not have proof
340mopar is offline
