Pre Alphas
Old 04-21-2016 | 08:25 AM
  #41
Originally Posted by phragle
Amongst all the other suggestions, if you are doing bellows etc while its off, do yourself a favor and do the shift cable too. Alpha's and prealphas LOVE new shift cables and it keeps you from looking like a douche around the docks.
at this point I do not plan to go as far as the bellows.
I will do all bellows and cables in the next phase.
(Unless this phase mandates.)
First things first, I need to get her fired up and in the water.
if all runs well and sounds, looks, tastes good I will go the next step.
340mopar is offline
  #42
Originally Posted by sprink58
Go to this link...might help you out.
http://www.boats.net/parts/search/Me...985/parts.html
I'm not finding my number on this database ...
OD651968
340mopar is offline
Old 04-21-2016 | 08:35 AM
  #43
OD651968
Me either...not finding a series that starts with "OD"...could we be missing something ? If it were "D6511968" it would be a '87~'92 Gen ! Alpha from a 170 HP V6...probably a 1.65 gear...but the "O" puzzles me.
sprink58 is offline
Old 04-21-2016 | 09:00 AM
  #44
OK...did some digging and went to Mercruiser Parts http://www.mercruiserparts.com/r-mr-...rive-1983-1990.
Based on the numbers yours could be an Alpha I in the 1983-1990 series of production. Also...if I plug that number in as zero D it comes back as a 540 HP Big Block so it's not that. LOL
Good Luck
sprink58 is offline
Old 04-21-2016 | 09:32 AM
  #45
the Marine folks here looked it up (somehow) and said it was a 17 July 1991, 1.50:1 RH unit
OK
I just looked itr up here:
https://www.perfprotech.com/mercury-...g/searchserial
and I got:
Serial Number: OD651968
Product Line: MERCRUISER
Year : 1990
H.P.: ALPHA ONE
Model Number 5010150CS
Model Description: R/MR ALPHA ONE STERNDRIVE
MERCRUISER 1990 ALPHA 5010150CS R/MR ALPHA ONE STERNDRIVE
340mopar is offline
Old 04-21-2016 | 11:01 AM
  #46
OK
and I got:
Year : 1990
H.P.: ALPHA ONE
OK...so now you know.
sprink58 is offline
Old 04-21-2016 | 11:41 AM
  #47
Next question ... will the Alpha One's mount-up to the MC-1 Gimbles
340mopar is offline
Old 04-21-2016 | 02:18 PM
  #48
I know of no issues doing that. I did it on my '79 Formula be fore converting to Bravo I's and it was plug and play. I did change the U-Joint Bellows when I did it because one of mine was torn. Also a good time to take a look at the Gimbal Bearings. If you have torn u-joint bellows you get this:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
...so check your U-Joint Bellows carefully for any signs of leakage.
sprink58 is offline
Old 04-21-2016 | 02:40 PM
  #49
Roger that! I will check them out!
I was told the drives would bolt-up
I was also told they would bolt-up but are shaped differently and would not look good (and may leave a gap for water to get into.
340mopar is offline
Old 04-21-2016 | 03:04 PM
  #50
No...they will look good !!
sprink58 is offline
