4.3 to 5.7 swap
Old 06-26-2016 | 08:41 PM
Default 4.3 to 5.7 swap
I have a 2004 Crownline 180 and I am installing a 260hp merc 5.7. My boat currently has the 190hp 4.3 with the 1.8 gearing, but I have the option to run the 1.5 gearing that came with the 5.7. I have read a lot of things that said the 1.8 will work fine and they make plenty of props for it. I have also read that with equivalent props, the 1.8 will actually net me a higher top speed. I was wondering what everyone else thought of this. I plan on pulling the motor in a week or so. Thanks for all the help in advance.
Ryan
lilryan is offline
Old 06-26-2016 | 10:13 PM
I would run the 1.5. It's the drive made to run with that engine. A 1.5 drive would run faster than a 1.8 using the same prop at the same engine RPM.
picklenjim is offline
Old 06-26-2016 | 11:04 PM
BUP
gear ratio also moves your power bands per rpms
there is reason why marine apps have different gear ratios for different engines.
For the 5.7 Merc did use 1.47 and 1.50 and a 1.65 if I recall the 1.65 was for the 210 hp 5.7 / 350 CID Mercruiser..
BUP is offline
Old 06-27-2016 | 07:48 AM
Yes you want the 1.5.
wannabe is offline
Old 06-27-2016 | 09:09 AM
Thanks for the advice. What I meant by the same prop was, a different pitch for the different ratios, but in the end the final ratio was the same. I understand what you are saying.
lilryan is offline
Old 06-27-2016 | 09:11 AM
I know my buddy has a 5.0 in his Crownline and it has the 1.65 ratio as well.
lilryan is offline
Old 06-27-2016 | 10:46 AM
I will swap the upper unit at the same time I put the engine in. Thanks for all the advice.
Ryan
lilryan is offline
