broken top cap stud bravo XR >
Old 07-20-2016 | 09:11 AM
Default broken top cap stud bravo XR
working on sons AT stud broke off just below housing surface, pulled drive, have drilled with left hand bits, tried EZ outs, has not budged, any idea's ? thanks Rob
ezstriper is offline
Old 07-20-2016 | 10:37 AM
let WD 40 soak in the hole overnight.
If that doesnt work, heat it.
Something you should do anyway is drill & upgrade all the studs to 7/16. I swear it makes them flex less and have higer torque on the bolts.
Keith Atlanta is offline
Old 07-20-2016 | 01:59 PM
already is 7/16 been sitting overnight now, was not sure how to heat with being assembled
Old 07-20-2016 | 02:45 PM
Its not the stock 3/8? How the fuch did you break a 7/16 stud? They usually strip first... Was it a real stud or was it some ordinary steel?
With the topcap off heat the inside corner with a propane torch.... At least thats what I did.
Old 07-20-2016 | 11:18 PM
Lay a 1/2" nut on top of the stud and weld the nut to the stud. As soon as it stops glowing red, put a wrench on it and back it out. The heat should make it come right out. May have to repeat it a few times if the nut breaks loose, but be patient and it will come
snapmorgan is offline
Old 07-20-2016 | 11:39 PM
Probably corroded in due to be dissimilar metals. PB Blaster soaking overnight and then heat.
ATF mixed with mineral spirits is also a supposed to be a very good penetrating solution.
Griff is offline
Old 07-21-2016 | 08:00 AM
soaked couple of days now, tried heat, cold, been drilling a size or so at a time, right to edge of threads, no go, going to just helicoil at this point, frozen worse than I even saw...
Old 07-21-2016 | 08:01 AM
it was broken off below the surface of the housing..knew the weld trick but did not think could get enough contact to weld
Old 07-21-2016 | 08:05 AM
Always use gold/brown anti-seize for dissimilar metals on reassembly
class6 is offline
Old 07-21-2016 | 08:54 AM
Because its a F'in boat, LOL. Its a nice stainless stud. Im sure its from Max Machine Worx, as thats whos drive shower is on it.
TooLateVTEC is offline
