Help ! Powder Coating Transom Assy and Drives. Does it Last ? >
Old 02-20-2017 | 07:34 PM
I had my extension box and all transom assembly parts powder coated before last season. My guy actually used a heavy duty powder coat. They use it a lot for atv, dirt bike and truck parts. He told me it could be sanded and buffed if I had too. The imco castings were very porse so he also used a powder coat filler. It worked pretty well but he also said it was a PAIN to work with. The stuff basically would dry up immediately upon contact with the metal, weird stuff.
So far all the parts still look great. I let one of the sharp corners of a steering ram bang against one of the steering arm and that did cause the powder coat to chip off. So that one will get redone. My boat does stay on the trailer and in water overnight maybe a couple times a season and there's no salt water near WI. Thus far I am happy with the powder coating.
IGetWet is offline
Old 02-20-2017 | 08:16 PM
The parts went to the powder coaters today , so well see how they last!
dunnitagain is offline
Old 02-24-2017 | 06:36 PM
Hi there,
My extension box and drive are powder coated. Been that way for at least ten years. I trailer and run in fresh water. I leave the boat in for 3 days max. There is normal wear on the skeg from sand just like paint. I was told to use polyester based coating. I am pretty happy with it.
If one were to powdercoat or paint aluminum by the book, the bare metal will have an Alodine conversion coat first.
Happy boating,
Jeff
hallj is offline
Old 02-28-2017 | 12:39 PM
Here , where the u.v. factor is high , blues blacks and red powder coats dont fare to well with normal exposure to sun .have not heard if there are improved formulas out that are up to imron quality yet.
The nason line of urethane is the next best thing , esp in reds and blacks..
You could almost spray a dirty dog with that stuff , and it will stick.
airjunky is offline
Old 02-28-2017 | 12:52 PM
My drives are black Imron over 2-part epoxy primer over acid primer. 10 years still shiny, but a few bumps and bruises.
K-planers were powdercoated black at same time, still coated very well, but I do notice they are not as shiny (never were, but worse) almost a semi-gloss finish.
CDShack is offline
Old 02-28-2017 | 01:09 PM
put a good clear with UV absorber over the powdercoat. Nice shine and protects the pigments from UV light.
kvogt is offline
