-   -   Sixes to M8's who's done it? (https://www.offshoreonly.com/forums/drives-lower-units/345328-sixes-m8s-whos-done.html)
aex 03-11-2017 03:42 PM
Sixes to M8's who's done it? What challenges did you face?
Unlimited jd 03-11-2017 03:53 PM
8 is shorter so I imagine there will be some setup to do again
offshorexcursion 03-18-2017 09:31 AM
Interesting.....It does seem like people like the M8 more than they used to, would be cool to hear more about them.
aex 03-18-2017 10:16 AM
These were delivered with 2 inch spacers so same height. We will run them and then decide if an adjustment would be appropriate.
aex 03-18-2017 10:28 AM
The M8R has a hydro-dynamically more efficient lower gear case than the original M8. The mechanics of this conversion are straight forward however the bullet measures about 1/2" larger in diameter and the skeg is thicker. I was hoping someone had done this and could shed some light on handling characteristics. They are rated at 1600 ft lbs vs 1160 for the #6 so hopefully these will stay on the boat Lol. Seriously, the #6's are great units that can for sure handle more than 1160 Ft lbs. We ran them at at almost 140% of their rated capacity and finished races, broken, worn out yes...but finished all except one.
ICDEDPPL 03-18-2017 10:55 AM
Aren`t the M8`s double the price?
aex 03-18-2017 11:25 AM
Probably not double but I don't know what new sixes cost.
Boatlesss 03-18-2017 10:56 PM
Sounds like your going to be spending a lot of $$ and still have breakage issues. Didn't the MTI's break the hell out of these things too?
aex 03-19-2017 11:11 AM
I don't know. Where did you hear this? I know this drive is improved since it first came out and Merc puts it behind their 1750, and warranties it behind a 1350.
Thanks for the heads up.
kidturbo 03-19-2017 11:22 AM
3 Attachment(s)
In the middle of a #6 to Weisman upgrade for similar reasons.
I'd consider going 6 to 8's a walk in the park..:)
[ATTACH=CONFIG]565682[/ATTACH] [ATTACH=CONFIG]565681[/ATTACH] [ATTACH=CONFIG]565680[/ATTACH]
