MDC Drive Sync
Old 07-29-2017 | 08:44 PM
bck's Avatar
bck
Charter Member#568
Originally Posted by sutphen 30
so you need the trim position sending unit on the drive?what are you guys w/ hp transom assemblies doing?I have no senders on my drives,,just cables.
same here.
Straight bottoms and flat decks
bck is offline
Old 08-01-2017 | 12:18 PM
MDC has a parts list from Mercury that will allow you to run a Drive Sync.
mike38scarab is offline
Old 08-01-2017 | 06:09 PM
bck's Avatar
bck
Charter Member#568
I wonder if the system can interface with the led indicators that have been out a couple years now.
Livorsi Marine, Inc. - LED Position Indicators
bck is offline
Old 08-01-2017 | 06:53 PM
DriveSync is compatible with all aftermarket LED indicators including Livorsi and Mayfair as well as Mercury's SmartCraft. NMEA 0183 and 2000 outputs are also available to support glass panel displays.
GF?
Got Freedom? is offline
Old 11-01-2019 | 12:17 PM
Bump. For those that have this, are you still happy with the results and it's still working as advertised?
Thanks!
Madman7 is offline
Old 11-01-2019 | 12:43 PM
Thanks!
I installed a drive sync this summer, I bought the Race version with the 2 presets. super product I can just hit a toggle switch up for 1st preset, then same toggle down for second preset, or use the trim switch for normal operation.
It is super Bad A$$. I have no problem recommending this product. also the customer service from Mike is Fantastic!
abones is offline
Old 11-01-2019 | 01:14 PM
Yep - product is awesome and Mike Clesceri is great to work with, as well. He cares about the product and his customers satisfaction. I too would not hesitate to recommend - my opinion is no 90+ mph boat should be sold without it.
Thanks!
ALL_IN! is offline
Old 11-01-2019 | 03:07 PM
^^^ Thanks all.... Ordered
On different note, anyone have any experience with the IAC Survival Kit. Is it a necessary item?
Madman7 is offline
Old 11-01-2019 | 04:28 PM
VoodooRob's Avatar
if you have 600 or 700s make sure you do the circuit protection from Merc, there was a service bulletin about it. Have your engines looked up in the database to verify, BUP on here stocks the kits and can look up your engine history for this bulletin and others.
VoodooRob is offline
Old 11-04-2019 | 07:57 AM
I made my own fuse jumper harnesses. Details are in a post a few years ago. 1 amp fuse.
ALL_IN! is offline
