Leaking drive oil
Old 06-28-2017 | 09:14 PM
Default Leaking drive oil
I had to keep adding drive oil to my boat today. It appears to be leaking into the engine compartment back by the transom. Looking at this diagram Bravo One XR (Drive & Transom) Mercruiser 0L914990 THRU 0W239999 Oil Reservoir Components Diagram and Parts
Will I be able to get any of those fittings in the back or does this job require removal of drive or engine?
Plan to dive into this tomorrow.
D2HP is offline
Old 06-29-2017 | 07:56 AM
I recently replaced the lower fitting on my customers 25 Outlaw,,did not remove the engine, but I had to remove about everything behind the engine to get to it,,its a job,,these fittings should not be plastic.
253 is offline
Old 06-29-2017 | 09:13 AM
Thanks for the reply 253. Not looking forward to it!
D2HP is offline
Old 06-29-2017 | 08:44 PM
offthefront's Avatar
Make sure its not the Drive Bottle cap Itself .....or also the driveshaft seal could be leaking and dumping oil into the Bellows and then into the bilge ....m
offthefront is offline
Old 06-29-2017 | 09:41 PM
Or the bottle itself cracked near the bottom. The plastic fitting? Into the transom assy? I used a piece of brake line from auto parts store.
dereknkathy is offline
Old 07-02-2017 | 09:50 PM
It ended up being the driveshaft seal. Ran the boat for the 1st time since pulling the drive to fix the seal. Had the bottle go completely empty again but it has seemed to stabilize now.
D2HP is offline
