Blown bravo one drive? >
Old 08-21-2017 | 08:31 PM
Default Blown bravo one drive?
I was out on my boat and all of while cruising about 3500 rpms and all of a sudden the motor revved way up no forward or reverse in water when I throttle it up to about 1500 2k rpms I hear a ratcheting noise. On trailer now I don't hear noise. No forward only reverse I suppose because there is no load. Tight spot while spinning prop. When motor is not running I cannot shift into forward gear. I was thinking I have to pull upper unit apart but figured I'd throw this call for help out first for some possible guidance. Thanks for any feedback anyone can help with.
riverrunner242 is offline
Old 08-21-2017 | 08:56 PM
Rookie's Avatar
Probably blew the upper. (floor out of the gear) Common symptoms.
Rookie is offline
Old 08-21-2017 | 09:37 PM
offthefront's Avatar
Drain the oil and check plugs for metal ..... remove the top and rear cap ....
Attached Thumbnails Blown bravo one drive?-20170821_224206.jpg   Blown bravo one drive?-20170821_224212.jpg
offthefront is offline
Old 08-21-2017 | 11:00 PM
My bets the coupler went
JaayTeee is offline
Old 08-29-2017 | 09:36 PM
Thanks im pulling upper apart this weekend
Old 08-30-2017 | 01:42 AM
Drain gear lube, pull top cap and back cap is all you need to do to inspect it.
Griff is offline
