Still rattling
Old 04-26-2018 | 07:44 AM
35fountain's Avatar
Originally Posted by badmonkey
Mine do it.... its normal. just rebuilt both drives with fresh gears, new gimbal bearings, new everything...the rattle is normal...totally non issue.
ok...my other drive doesn;t do it and 15 high performance boats at my marina don't do it
35fountain is offline
Old 04-26-2018 | 07:48 AM
35fountain's Avatar
Originally Posted by Clustergear
Yes I would try swap too. The reason I brought this up is I have run into this before. With drive off there was no noise, with drive on and in the full down position rattling noise. Guessing the back pressure on exhaust with drive on and down gets the metal bouncing around in there. I have heard many boats that had noises that sounded like gimbel bearing problem while running on trailer, but when boat was put in water noise would be gone. Did you check coupler and lube it before putting drive on. Worn coupler or dry couple can make noise at idle. I see you have gone through drive, just trying to give you some other things to look at. I see your in NY if you are any where near my me I’d be glad to take a look at it. I’m in LG
I Appreciate it.. we are a bit far./ I am near Westchester on the Hudson River
Old 04-26-2018 | 07:56 AM
I’m from DobbsFerry moved up here after I retired.
Clustergear is offline
Old 04-26-2018 | 06:00 PM
35fountain's Avatar
So we are pretty close then....I'm just north of Haverstraw Marina
Old 05-03-2018 | 01:10 PM
Mr Gadgets's Avatar
Charter Member #601
Put your hand on top of the drive, you will feel a vibration from the shift fork cam bouncing up and down as the bump rings spin around and the space between the gears, moves up and down. Now shift it into gear. It should quiet down, as the linkage is holding towards the gear the cone is engaged with. Some make more noise than others, depends on gear stack, etc.
Hope that helps.
Dick
Mr Gadgets is offline
Old 06-10-2018 | 07:10 AM
35fountain's Avatar
Update......I was out on 2 runs only this season so far and now the noise got much louder....No unusual vibrations felt...
check this out
Old 06-10-2018 | 09:43 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
check this out
https://www.youtube.com/watch?v=dIYEFbXIUxo
I am going to suggest getting two 10' lengths of plastic downspout corrugated pipe (solid kind, not holes), and tape it up to your exhaust to help isolate the exhast/motor noise away from the drive when you are troubleshooting and filming.
I don't doubt you that you hear something in the drive. I can hear something in the video, but I can't discern any details about it.
Sydwayz is offline
Old 06-11-2018 | 01:30 AM
BUP
buy a real doctors stethoscope. I have been using one for 15 years now. It is used for multi testing marine engines and noise testing , fuel pumps, fuel injectors, bearings in pulley's and of course outdrives, .
Wonder if its U joints. - When ever I pull all that assembly apart for changing U joints , I mark the shaft - yoke and input shaft . -- then put it all back together by the marks I made. Line to line to line. This keeps the balance of the assembly like how it was.
Pull the drive off --- stick a quality alignment tool in the coupler -- start the engine - How much of a perfect circle is the alignment tool making when the engine is running ? If not, then the coupler is warped or loose or coming apart. That could be the issue.
As mentioned swap the good drive over and then run the engine to see if noise goes away. If so, its a drive issue / or U joint issue. If not then no drive issue or no U joint issue.
BUP is offline
Old 06-13-2018 | 06:25 AM
35fountain's Avatar
I appreciate your input, good points...as for the coupler, Wouldn't there be a noise behind the engine if the coupler was the culprit.. I can stand in my engine compartment with engine running and i can get behind the engine. All i heard was the engine. but the knocking noise you can only hear while standing behind the boat and you can here it over the exhaust noise.. As for the u joints..I replaced the complete input shaft assembly.This comes with u joints, front shaft, rear shafr coupler, everything except the gears and bearings..They checked out fine...The only thing i notice now is the noise is louder. So i will be bring the boat to the marina and let my mechanic listen to it...Its hard to pin point it in the video..but listening closely there is a rattle besides the cam sound that is not even with the cam.
Old 06-15-2018 | 01:13 PM
I had a drive do this once and it was the gimble bearing not tapped in far enough. was the strangest thing.
Bajaorlando is offline
