Cleaver props on SCX >
Old 06-09-2018 | 01:44 PM
Default Cleaver props on SCX
I have SCX 1400 lowers with 1 7/16 shafts. What would it take to run cleavers, if anything (adaptors?)? It appears the #6 prop shafts have less spline length but may be larger diameter (1 7/8" maybe?) I haven't compared in person. Currently running 32p maximus but I think I may have too much wheel there. If i went to a larger diameter prop i could remove the 1/2" spacer from the drives and maybe gain a little cruise speed in the process. Currently cruises around 71-72 @4000 rpm. Just cruising through options.
This is on 38 powerplay with 825efi
AJ POWERPLAY is offline
Old 06-15-2018 | 07:33 AM
Also considering 6 blade herings but cannot find anything to fit 1 7/16 shaft
Old 06-16-2018 | 06:53 AM
IMCO makes a 1 7/6" shaft to #6 prop shaft adapter.
99silvergts is offline
