Quote below is from IMCO installation manual.
9. SCX Drive is 19 7/8” from crankshaft center line to prop shaft center line (2” shorter than standard Bravo). SCX4 Drive is 17 7/8” from crankshaft center line to propshaft center line (4” shorter than standard Bravo). I am 100% sure you are WRONG. SCX upper is 2" shorter. |
If a SCX upper was indeed shorter, you wouldn’t be able to use a SC or merc lower on it, The vertical shaft would be too long, which isn’t the case |
If a SCX upper was indeed shorter, you wouldn’t be able to use a SC or merc lower on it, The vertical shaft would be too long, since you can run these, they must be the same |
https://cimg3.ibsrv.net/gimg/www.off...eb305a9c0c.jpg
This is my set up. IMCO SCX upper standard SC lower with standard vertical shaft. Propshaft is 2" higher than standard Mercury XR. If you want a real answer to your question and not a bunch of guesses, call Fred at IMCO. |
SCX-4 upper is same dimensions as scx except for the cavitation plate that is bent up (lower to upper bolt pattern also different) to allow for the -4 lower prop clearance. The lowers are the difference between them. But yes a scx with a scx lower or a scx with a -2 sportmaster or -2 sc lower make the same x-dimension as a bravo with a -2 lower.
Originally Posted by 99silvergts
(Post 4655586)
This is my set up. IMCO SCX upper standard SC lower with standard vertical shaft. Propshaft is 2" higher than standard Mercury XR. If you want a real answer to your question and not a bunch of guesses, call Fred at IMCO. correction: Those are standard lowers, angle of cav plate tricked me. So your setup is the same X-dim as a standard bravo setup. |
Originally Posted by IGetWet
(Post 4655611)
But in any case silvergts is wrong lol
Originally Posted by dsmawd350
(Post 4655662)
I was just talking to jeff Harris to confirm. He said the scx4 is -2 in the upper -2 in the lower. Regular scx upper and lower is -0 in the upper -2 in the lower.
https://cimg0.ibsrv.net/gimg/www.off...cd67ed7d46.png https://cimg1.ibsrv.net/gimg/www.off...77597d9a59.png |
(Post 4655529)
9. SCX Drive is 19 7/8” from crankshaft center line to prop shaft center line (2” shorter than standard Bravo). SCX4 Drive is 17 7/8” from crankshaft center line to propshaft center line (4” shorter than standard Bravo). I am 100% sure you are WRONG. SCX upper is 2" shorter. The SCX upper is the same height. |
| All times are GMT -5. The time now is 04:45 AM. |
