What is this?
Old 10-24-2018 | 06:37 AM
https://photos.app.goo.gl/7uwQvDuquRxu2orXA
TurboTim is offline
Old 10-24-2018 | 06:50 AM
Mechanical trim actuator, should be attached with stainless clamps.
The black rod is spring loaded and attached the the cable. If the stainless tube/guide (the one with zip ties) is not snug on the ram it will just slide.
badluck is offline
Old 10-24-2018 | 06:54 AM
So is that why there is that extra piece on the end of the trim rams?
TurboTim is offline
Old 10-24-2018 | 07:29 AM
If you put the drive down (assuming your indicator on the helm is in working order) and if the Zip ties can hold it in place you will see the black plunger contacts the Stainless fitting.... as the plunger is pushed in as the drive tucks in - the indicator moves accordingly.
Definitely put on the Stainless clamps (make sure Band and Screw is SS) to hold the cable in place on the ram
speicher lane is offline
Old 10-24-2018 | 07:38 AM
Do bravo drives not have the sensors in the gimble area?
TurboTim is offline
Old 10-24-2018 | 08:31 AM
Some do but they are subject to corrosion and they aren't reliable thus the mechanical type are used.
payuppsucker is offline
Old 10-24-2018 | 05:02 PM
it looks like you are missing the cradle that goes between the trim cylinder and the indicator tube. you have to have it to hold it off the trim cylinder at the correct angle and it has notches in it to locate the clamps. the spring in there is pretty stout so with out it clamped properly it will slide
compedgemarine is offline
Old 10-24-2018 | 05:07 PM
https://teaguecustommarine.com/em001...uator-kit.html
the black piece at the top and the two clamps are what is missing
Old 10-24-2018 | 06:24 PM
The zips ties are amazing
Sunny32SSR is offline
