Merctrans II parts >
Merctrans II parts
Merctrans II parts
Old 04-03-2021 | 06:58 AM
  #41
cig28's Avatar
Originally Posted by Jasonw
I'm in need if a seal kit for my merctrans 2 any idea where I can get one . I have looked all over the web and not luck and it need to get it back together
I might have a couple of kits.
cig28 is offline
Old 04-03-2021 | 07:37 AM
  #42
cig28's Avatar
I have 4 seal kits.
cig28 is offline
Old 04-03-2021 | 12:20 PM
  #43
Thank you every one I found one so hopefully I can get this thing going again
Jasonw is offline
Old 04-09-2021 | 07:35 PM
  #44
Id be interested in a seal kit.
Formula260c is offline
Old 04-09-2021 | 09:11 PM
  #45
I have to order a few seals to complete the kit if you don't mind waiting. Should be ready to ship next week. Thanks RD 360-739-7159
Tahiti25 is offline
Old 11-01-2021 | 09:48 PM
  #46
Default MercTrans seal kit
Hi, I'm looking for a seal kit as well. Specially the clutch piston outer seal.
Thanks.
peugenio is offline
Old 11-01-2021 | 10:47 PM
  #47
peugenio give me a call tommorrow, i may have what you need. Thanks RD 360-739-7159
Tahiti25 is offline
Old 11-03-2021 | 10:04 PM
  #48
Default Seal kit
Hi RD,
I just saw your reply. I'll give You a call tomorrow.
Thanks,
PEL
peugenio is offline
Old 11-13-2021 | 08:07 PM
  #49
Originally Posted by Tahiti25
... i may have what you need. Thanks RD 360-739-7159
hi. I'm looking for a seal kit for Merctrans 2 as well. The rings for pistons, oilseals for shafts and so on.
Is it something you could help me with?
OldYoungMariner is offline
Old 11-19-2021 | 10:37 AM
  #50
Hello, I have been following this thread in hopes of getting my Merctrans B back in my boat. I had bought seals from Kirk in Wa so this rebuild has been going on forever. I dont mean to highjack but I am in a bad way. After several shops rebuilding my Trans I installed it in the boat last week. First time I installed it the shaft was not moving and once installed it was locked in forward regardless of where the shifter was. Pulled it again and made sure the shaft was free spinning before putting it in the boat. Its doing the same thing, When I start the motor the trans is in forward but when I put it in reverse it dies. I am at my wits end gentleman. I restore old Motorcycles, not boats.
I was going to buy one of Kirks trans he sold for around 2500 but thought I could save money by doing it local and I was so wrong. At 60yo I am not sure I have another R&R in me and you cant find anyone that knows what they are doing in this part of Tn. When we pulled the trans it had lost forward, clutches, seals and a gear was replaced.
I know I should of started my own thread but saw that this one was still alive. The trans shop that just rebuild it is asking me if there is any adjustments that can be made and all I see in the manual is something about the reverse band needing to be adjusted but this is on the port side so I am not sure I can get to it from the pics. This is a electric shift boat ( I know, they suck) but movement is the same as the other side that works fine.
Stuck in forward, dies when going in reverse. The reverse band has not been adjusted. The reverse lock seemed to be froze up but is now like the other side. Could the adjustment of the reverse band be my issue? The manual is hard to understand and I have read it 100's of times to no avail. I am asking for help from the folks in the thread. Any advise would go a long ways. Please help an old guy get back on the water. It has been a tough year and this boat is beating me.
Greg in Tn 931.239.0850
VintageBikesUSA is offline
