Bravo dropping overnight >
Old 04-01-2019 | 12:51 PM
wieland77's Avatar
Default Bravo dropping overnight
My friend has a 1993 Formula that the drive doesn't stay up, it will drop from the trimmed position overnight. Does not have any leaks internally or externally so i assume its a check valve in the pump. Can those be replaced or does the entire pump need to be replaced? Could it be bleeding off somewhere else besides the pump but not leak? Thanks for any advice
wieland77 is offline
Old 04-01-2019 | 01:04 PM
my formula did the same thing last year.... tested the pump first..... but it ended up being the pump. You can replace by itself. Think it will come with the tank.
MyIsland is offline
Old 04-02-2019 | 12:30 PM
wieland77's Avatar
So the entire pump assy needs to be replaced? There are quite a few on ebay, just wanted to be sure before ordering one.
Old 04-02-2019 | 12:45 PM
Do they make Viagra for boats?
ThisIsLivin is offline
Old 04-02-2019 | 12:47 PM
SB
Reggie Fountain put them in every boat they made.
SB is offline
Old 04-02-2019 | 01:30 PM
F-2 Speedy's Avatar
after you get it fixed, Id leave the drive in a neutral position for storage,
F-2 Speedy is offline
Old 04-02-2019 | 02:47 PM
Storing it with the drive up plays hell on the bellows as well. It’s fine if you’re yanking the boat every weekend for summer play but store the drive down for the winter months. The hydraulics will thank you too.
Baja Rooster is offline
Old 04-02-2019 | 03:29 PM
no he didn't. The stringers and transoms are limp as noodles.
Drock78 is offline
Old 04-12-2019 | 11:49 AM
Mine was doing the same thing it turned out one of the ball bearings in one of the check valves had a rust pit in it.
tbanzer is offline
Old 04-12-2019 | 09:00 PM
Tinkerer's Avatar
Mercury may have a rebuild kit for your pump.
It is not hard to do.
Tinkerer is offline
