Conversion from Trs to Bravo II need advice! >
Old 04-13-2019 | 06:10 AM
Smile Conversion from Trs to Bravo II need advice!
Hi Guys,
well quite a newbee here and with power boats :-)
here's a short description on whats going on
Boat: Wellcraft Excalibur 1988 42ft.
engines: 2xMercruiser MCM420 425hp with borg Warner trans and TRS drives
the drives are all rotted out, way past any hope
so ive bougth a set of new serviced Bravo II set up, and now we are in the think fase on how to install it the best way possible.
Is it possible to keep the engines in the position the are in now? it would be prefereble to have good work conditions in the engine bay if possible, if we move the engines back we lose all free space
So here is my game plan possible or not!!!
remove the BW trans install a set of used mercruiser 7.4/454 bellhousings have custom fabricated a set of driveshafts.
do you guys know of any spareparts needed or any one done this type of conversion ?
ive read almost all post's regarding trs/bravo conversions on the internet without any luck!!
so please help me..
Kind regards
Casper P
Vestskov is offline
Old 04-13-2019 | 07:20 AM
Yes, it can be done and the thread indicates what needs to be changed to start.
TRS to Bravo [Archive] - SeriousOffshore.com
AllDodge is offline
Old 04-13-2019 | 07:46 AM
Rookie's Avatar
I believe Bravo two drives are work boat drives. Not intended for use over 50 MPH.
Rookie is offline
Old 04-13-2019 | 09:35 AM
you can put the engines anywhere you want.so yes,it can be done.
sutphen 30 is offline
Old 04-14-2019 | 08:52 AM
Ayuh,..... Here's a Merc parts listin', showin' all the parts it takes to put in jackshaft drivelines,.....
Even though is says 5.0l, the BBC parts are exactly the same parts,.....
https://www.marineengine.com/parts/m...aft-components
Bondo is offline
