Borg Warner Velvet drive question >
Old 05-04-2019 | 09:05 AM
Default Borg Warner Velvet drive question
I have two 10-17 velvet drives. Looking to beef them up. In high school I rebuilt 7 turbo 400 transmissions. My hunch is these Borg velvet drives would be pretty easy to rebuild compared with a turbo 400 transmission. Any thoughts? The rebuild kit is about $200. What is the weak link in these drives? I’ve read adding more clutch plates helps.
who is best for such a rebuild?
im told 10-18 drives are stronger? Are the 10-18s a direct replacement. TRS outdrives on my 1986 30 foot twin checkmate
your thoughts would be greatly appreciated.
cliff in maine
cdowjr is offline
Old 05-07-2019 | 07:18 AM
Talking
cliff in maine
there is a difference in overall length. if i remember it was about 3/4 inch different in length. i broke the c-71's in 33 scarab, replace it with c -72.
they can make a c-71 into a c-72
my now 38 scarab has had c 72s,,trs,, since made ,,1989,,boat has had 600 hp motors for last 25 years.
now i have about 700 hp....
flashgordon is offline
Old 05-20-2019 | 06:19 PM
O
Both all rebuilt. Just like new. Anyone need 2 of these. I’m upgrading to 1018s Have 2 coming I bought off eBay to rebuild
cdowjr is offline
Old 05-20-2019 | 06:20 PM
cdowjr is offline
Old 05-23-2019 | 05:41 AM
I can’t figure out why the pump housing bolts would not leak? Any thoughts? One rubber seal goes around the outside edge. The bolts don’t have gaskets on the heads. Seems like the pressured hydraulic fluid would go to the bolt, up the shaft & out the head? Only reason it might not is too machined surfaces mating perfectly! Any thoughts?
Cliff in maine
cdowjr is offline
Old 05-23-2019 | 05:42 AM
Also where do I get that donut gasket that goes on the tail shaft where it mounts into the TRS drive
cdowjr is offline
