What's the story on this,  Blackhawk surface drive? >
Old 10-14-2020, 11:52 AM
Originally Posted by Mbam
I would let some go. What do you need?
You have any props?
12meter joe is offline
Old 10-14-2020, 12:07 PM
Offshoreonly Advertiser
Mbam's Avatar
Originally Posted by 12meter joe
Wouldn't mind having a vertical shaft and a case?
Do you know what version you have? If possible post a picture of your existing stuff.
I do have some props but I don't think I want to shake any loose at this point.
Mbam is offline
Old 10-14-2020, 07:27 PM
Old 10-14-2020, 07:51 PM
Friend of mine has one on a Concord Mach II with a 350 MAG MPI and it’s an absolute blast to drive. If I remember right his seems to like more of a neutral trim setting vs flying the nose a little higher with a traditional drive. Boat runs about 72 or so with it on there
87MagnumII is offline
Old 10-14-2020, 10:47 PM
That looks like an absolute blast of a boat!
Baja Rooster is offline
Old 10-15-2020, 06:38 AM
Mbam's Avatar
I hate to tell you this but I need to see the inside of the case with the upper gear set out. There are at least 2 versions. One has a shaft setup just like a Bravo. I'll post some pics later.
Mbam is offline
Old 10-15-2020, 06:58 AM
Oh I thought you were talking about the case itself. I do have some part numbers from replaced gear sets. Will that help or you need to see the Inside?
Old 07-13-2022, 09:09 AM
Yes if that was an original Blackhawk boat the hull is set up for it. And it really likes it Probably worth almost 10 mph over a standard Bravo boat.
As far as parts hard to find a good number of the components are the same as a Bravo 3. And drives come up on Ebay all the time.
I happen to have 8 brand new housings and enough new parts to put together 4 complete drives.
would you be interested in selling any? Or parts?
Hi3204 is offline
Old 07-13-2022, 03:22 PM
Mbam's Avatar
Sure, what are you looking for?
Mbam is offline
Old 07-14-2022, 08:10 AM
offshoredrillin's Avatar
Received 1,295 Likes on 449 Posts
i responded to your message, i still have a drive and a set of props for sale.
offshoredrillin is offline
