Newbie changing drive oil...Bravo 1
SubscribeQuote:
I will look...can you send a picture? Is this dipstick an accurate way to check oil level? Can I top it off through that?Originally Posted by AllDodge
If that is an original 1988 Bravo it will have a dipstick in the top cover. In 1989 the lube bottle was introduced
Quote:
Where do I find "exactly" what units I have? They are hard to read but I believe my outdrives are:Originally Posted by AllDodge
Starboard -
Port - 0B899877
AllDodge
close
- Join DateNov 2009
- LocationKY
Liked:500 Times in 386 Posts
Those are the first serial number range
https://www.mercruiserparts.com/brav...-thru-0f729999
Look at the top cap for the dipstick (item 11). If its not there it may have been replaced
https://www.mercruiserparts.com/bam/...y/30966/952/70
cheech
close
- Join DateAug 2010
Liked:565 Times in 340 Posts
Look at the top cap for the dipstick (item 17). If its not there it may have been replaced
FixedOriginally Posted by AllDodge
Those are the first serial number rangehttps://www.mercruiserparts.com/brav...-thru-0f729999
Perfect...dip stick is intact on both...will monitor!
Thanks, job completed. I got a little oil can/pump to top it off...worked great!!!
https://www.acehardware.com/departme...l-cans/2136786
zz28zz
close
- Join DateFeb 2013
Liked:392 Times in 243 Posts
Do yourself a favor and buy or make a pressurized oil dispenser to fill drive from bottom. A lot of us use a plastic bug sprayer modified to connect to drive. Others have purchased dispensers especially for this purpose. You'll never have to worry abt introducing air again plus it's much easier, faster and cleaner.
