Originally Posted by AllDodge
(Post 4755965)
That doesn't sound right but ok
The wire that energizes the relay should be white/green stripe, and when jumping from the red wire to the post on the right this would have caused a good spark You need a volt meter not a test light |
(Post 4755965)
The wire that energizes the relay should be white/green stripe, and when jumping from the red wire to the post on the right this would have caused a good spark You need a volt meter not a test light https://cimg8.ibsrv.net/gimg/www.off...79c46b148.jpeg |
And is the trailer up button on the same system as the up solenoid? That’s still just clicking..... With it clicking but not going up, then I would suspect the up relay is also the issue but could still be corrosion |
(Post 4756920)
The trailer button bypasses the trim limit which is on the port side of the drive. In post 8 it is item "h"
Originally Posted by Prestigeworldwideee
(Post 4756926)
Yeah, I did get a click when I bypassed the switch with the power wire. So what should I try cleaning off? The ground post?
(Post 4756931)
The best test is a voltmeter. If you connect the meter probe to the relay and when its energized there should be no voltage drop. If there is a voltage drop then there is corrosion. If no drop then its the relay
If the positive meter probe is on any of the Red, Blue/White or Green/White wires and the negative probe is on the Black ground, there should be 12V on the wires when selected.
Selected meaning press up and Red and Blue/White wires should stay 12V Pressing down, the Red and Green/White wires should stay 12V |
(Post 4756946)
I'm not there, only testing can say if it needs replacing, but as you say its cheap, so maybe just replace
(Post 4756960)
| All times are GMT -5. The time now is 02:08 PM. |
