Bravo one X to XR conversion cost >
Old 10-30-2020 | 11:25 PM
Hurricanes drive up the cost of lumber. With do many zinging in from the gulf this year it'll be a while before supply catches up with demand.
Smitty275 is offline
Old 10-31-2020 | 07:25 AM
Originally Posted by 87MirageIntruder
In the reading I've done on here (and many posts from you Keith) it does seem there is a difference of opinion on XR gears. Max Machine in Havasu said there were some bad runs of XR gears for a while, but now things seem to be better.
Also for clarification, my X drive has 400hrs behind a stock 496HO. I just dropped in a 600+ HP whippled engine so I need to do something. I'll be running a bravo 4 blade likely 28 or 30P with 1.5 gears on a Nordic Heat 28'.
As mentioned, you’ll never get 400 hours out of a XR set, if it’s a budget issue, put in a new set of X gears, they’re about $800 cheaper than XRs and the don’t do this.
JaayTeee is offline
Old 10-31-2020 | 08:00 AM
When AAD rebuilt my XR he put X gears in along with his shaft and beefed up top bearing. It is in a 29 foot Velocity with a engine that dynoed at 560hp. Two seasons and no problems. Hope this helps.
Padraig
Padraig is offline
Old 10-31-2020 | 08:07 AM
Padraig
Thats a great package right there. Another upside is if you arent beating on it, the X gears will give many more hours of run time.
Keith Atlanta is offline
Old 10-31-2020 | 08:25 AM
As others have said stick with the x till it blows. Dont pin the throttles getting on plane. Also I would not run a 4 blade if you can get on plane with a 3 blade. Slip will be your friend.
Chris
Blueabyss is offline
Old 10-31-2020 | 06:00 PM
Well it sounds like a few of you think a fresh set of X gears could work for me. I know slip with a bravo 4 blade on this boat is about 18% so that should help it last. A 3 blade doesn't really work on a Nordic Heat, and actually a 5 blade performs the best. I can stick with a 4 blade though at 18%.
I boat in fresh water lakes and it's pretty calm. In the past 2 seasons owning this boat I haven't aired it out yet. I'm very easy on the sticks too so I guess it's worth a try. Only one way to find out! I'll get a stronger clutch shaft and cap etc while I'm at it.
You guys helped me out a bunch here. Thanks again.
87MirageIntruder is offline
Old 10-31-2020 | 09:42 PM
I forgot to say in my earlier post, I am running a 5 blade hydromotive left hand.
Padraig
Padraig is offline
Old 11-01-2020 | 06:35 AM
My experience has been a bit different. When I repowered my Donzi 22 with the 525 the almost new Bravo X upper broke on the first time out on the big water. The XR upper has been running strong for about 10 years now. So I will never be convinced the the X is stronger than the XR.
thirdchildhood is offline
Old 11-01-2020 | 08:14 AM
How many hours were on the x at that point?
Unlimited jd is offline
Old 11-01-2020 | 02:04 PM
About 100 hours. The upper gears broke and cone clutch stuck in forward gear. On Lake St. Clair.
