installing Bravo Transom >
Old 04-20-2021 | 06:46 PM
Default installing Bravo Transom
Should 4200 be applied to the transom before installing?
Zinger is offline
Old 04-20-2021 | 07:49 PM
Assuming you are installing either a brand new assembly or at least an assembly with a new rubber gasket. If your transom is nice, clean and flat you shouldn't need any sealer.
TomR is offline
Old 04-29-2021 | 03:37 PM
I just put a new HD transom assy on a 20 year old boat. The transom was clean and flat. I installed it dry as well.
smokediver is offline
Old 04-29-2021 | 03:53 PM
Same here, 20 some year old boat, installed dry, all good
AllDodge is offline
Old 04-29-2021 | 05:11 PM
My brand new transom assembly is going on a 26 year old boat getting a new transom in June. Feeling like I want to use some 4200 in there for good measure atleast around the thru hull studs whose holes can't be waterproofed.
Tractionless is offline
Old 04-30-2021 | 10:20 AM
when i redid my transom i sealed the exposed wood with fiberglass resin. that will waterproof the stud holes. i also did that to the key hole cut out
260cat is offline
Old 04-30-2021 | 06:58 PM
This sequence
These directions
Resin like mentioned, easy clean up
don't forget engine alignment.
outonsafari is offline
Old 04-30-2021 | 07:38 PM
Don't forget clearance for tiller arm.
supposed to be drilled angled out.
RedBoatFl is offline
Old 05-01-2021 | 09:16 AM
The foam seal for use on the transom assembly is all you need. There's a lot of squish built into it. Adding goop just makes it look like crap and unprofessional.
And don't forget to open up the top for the tiller arm as mentioned above.
Smitty275 is offline
Old 05-01-2021 | 06:41 PM
That pic helps alot with figuring how to get resin into the stud holes. Thanks!
