Need help on picking a drive. Newbie here!
I recently was given a 98 advantage victory 27 from my grandfather and was curious as to what drive and engines to go with? Not sure if I should go to a bravo 1 or a bravo xr unit. I would like to build a 650-700ish big block Chevy just not sure where to start. Also boat doesn’t have engine or drive as it was stolen years ago from my grandfathers shop.
Richard
Richard
While I would tend to agree with Endeavor, on this particular hull an XR works fine. A had a 27 Victory for a few years and then bought a 28 Victory which has the same bottom and ran it for a few years. These hulls get on plane very easily, it takes about 2 boat lengths at 20% throttle and they have very high prop slip numbers in the 20%+ range. The combination of these two things is much easier on drives that other hulls. In the 10 years of owning the 2 Advantages, I only broke 1 XR drive and that was at 760hp on my 28 AFTER I added a drive spacer trying to get the slip #s down
