Dual down shafts performance >
Old 07-22-2021 | 06:28 AM
For comparison sake, my 06 38ZR imco SCX-4s are about 2” above hull bottom. Haven’t gotten a precise measurement on height or how far back they are. They are on ITS boxes. 17.25” 5 blades 18 degree rake. Planes out good with help of 280 k planes but isn’t challenging by any means. In a video that was taken with a go pro mounted in the notch you can clearly see the tip of the lower above the water. My slip isn’t the greatest however, 15-18 percent at cruise. From my experience and shops I’ve talked to the big imcos run the beat when up high out of the water and have a 16”+ cleaver to get around the big bullet and reach the water. There’s also the handling advantage with the cleavers. My boat was set up high to begin with with long sportmasters. 100+ 4 people coolers, full of fuel. 105 light, best so far of 108
IGetWet is offline
Old 07-22-2021 | 08:37 AM
i lost about 7mph but may need prop adjustments, but i have a low water pressure issue with mine, igetwet i see you have transom pickups, do you still send water through the drive to cool it?
b18cls1 is offline
Old 07-22-2021 | 08:53 AM
Yes water goes through the drive only from the lower pickup. The water exits out the two holes in the front of the drive top cap.
IGetWet is offline
Old 07-22-2021 | 09:10 AM
so the 1 1/4 hose inside is capped off?
b18cls1 is offline
Old 07-22-2021 | 09:18 AM
Correct.
IGetWet is offline
Old 07-22-2021 | 09:32 AM
Correct.
I’ve been trying to get an answer out of Imco about this and haven’t been able to. I figured it would be ok but just trying to make sure
b18cls1 is offline
Old 07-22-2021 | 09:47 AM
rvtransport's Avatar
Tori, I think you are spot on with your set up and bullets just surfacing. Most guys I know are running 15 percent slip when surfacing the propeller's. I will bet your water pickup location is causing you a little more slip also. Not sure on Donzi hull but on Fountains if you move water pickup to outside hull you will help with slip because props are getting cleaner water. Hope to see ya soon. Are running Top Gun poker run this year?
rvtransport is offline
Old 07-22-2021 | 10:49 AM
Yes we are looking forward to top gun! You probably right about the pickups down in the V, but they do scoop up enough water for the two stage pumps so I’m happy with that! I’ve asked a couple guys with NXT’s what their slip is but no one seems to know that or how high their drives are. From what they’ve told me about planing I’m betting they’re way up there though.
IGetWet is offline
Old 07-22-2021 | 10:57 AM
thats where im putting my pickups at id rather get good clean water all the time deep in the v to feed my twin stage pumps
b18cls1 is offline
Old 07-23-2021 | 05:46 AM
Quinlan's Avatar
Carter plumbed my drive intake water to exit out the transom. We were going to do like a drive shower placement to spray on top of drives but swim platform brackets were in the way so it comes out the center more.
Quinlan is offline
