Another Bravo 3 shift issue >
Old 09-21-2021 | 02:51 PM
Default Another Bravo 3 shift issue
95 Fountain, 502's with Bravo three's.
Starboard drive will only shift into reverse if shifted to forward first & then to reverse. If Drive is in neutral & shifted directly to reverse, it will not spin the prop. If I gently touch the prop with a piece of wood, it will bang like being shifted into gear & start spinning in reverse. New fluid, new shift linkage in outdrive, cable is an oem part. It worked fine a couple of weeks ago.
Ideas, suggestions or Input? Thank you.
smashm is offline
Old 09-21-2021 | 04:39 PM
Most likely the cone clutch and shaft is worn out, items 22 and 24
https://www.mercruiserparts.com/bam/.../30968/5398/90
AllDodge is offline
Old 09-21-2021 | 09:58 PM
Thank you for the reply. I pulled the rear stainless cap(Latham steering part) & found some metal shavings laying on the flat area. Drained the drive & ran all drive oil through a fine paint strainer, no other metal found & none on the magnet either.
Pulling the drive off in the morning, going to disassemble & put in a parts order. Thank you again for your input & help, it is very appreciated. I'll update to let you know what I find & I'm sure I'll have more questions. 😊
smashm is offline
Old 10-01-2021 | 11:14 PM
Pulled the drive last Friday, disassembled the top gears & clutch. Found the shift fork was very worn & grooved. Disassembled the gears & clutch to inspect, everything else was in beautiful condition. Ran to Offshore Performance & picked up a fork, reassembled everything & put the drive back on. Ran it on the hose, shifted perfectly. Finally got it back in the water yesterday, ran about 100 miles all day with no problems. Thank you AGAIN for the help, it is very much appreciated. It'll be back in the water for a cpl days for the races next weekend.
smashm is offline
