rubber and metal behind prop >
Old 06-01-2022 | 10:01 AM
Default rubber and metal behind prop
I have what looks like a rubber gasket and a metal piece behind the prop in the housing. Also looks like a small piece of a wooden shim that is further in. Any help on what it is and if I should remove it or something needs replaced? Its a bravo 1 outdrive.
bradysull is offline
Old 06-01-2022 | 10:24 AM
F-2 Speedy's Avatar
pull the prop and see whats up, no wood in a bravo
F-2 Speedy is offline
Old 06-01-2022 | 10:31 AM
Thanks for the reply. The props are off and it in the space around the prop shaft. I'm a new member, so as soon as it lets me, I'll post a pic.
Old 06-01-2022 | 10:39 AM
F-2 Speedy's Avatar
so its being used a shim / spacer ?.......might be the wrong hub for the prop shaft ?
Old 06-01-2022 | 10:55 AM
resurrected's Avatar
Welcome to OSO!
Eight more post in this thread and you can post pictures.
They don't need to be meaningful, but if you can make them entertaining it would be appreciated.
resurrected is offline
Old 06-01-2022 | 01:13 PM
Thank you! trying to be creative to get my 10 post....Well there's one more!
Old 06-01-2022 | 01:15 PM
SB
Just type useless one word posts every 30+ seconds from each other. Easy.
SB is offline
Old 06-01-2022 | 01:30 PM
Old 06-01-2022 | 01:31 PM
Here's the pics. Top one is the rubber and the bottom one is the metal piece I was talking about.
Old 06-01-2022 | 05:05 PM
Those are what’s left of the exhaust flaps that are supposed to be in the top of the y pipe
Unlimited jd is offline
