Bravo 3 info/help
So we are starting to look to upgrade our current boat to something like Formula 330 SS. Buddy I have has a '97 and said it was a great boat with 7.4's, but he recommended staying away from Bravo 3's? Guess he had a insurance issue and took out a drive and here in Ontario Canada, was just over $20,000 to get the drive off and replaced? I thought that was quite fishy but just asking for guys help and input on these. I thought B3's were a good drive?
Thanks John
Thanks John
Mine lasted 13 years/450 hours behind a 496 MAG before needing a full rebuild as the lower gear set began to pit and run metal thru the drive. Under $5K for a full rebuild thru AADS and that included re-chroming the prop shafts.
Maybe not a full rip, a new drive cost 10,500 for B1, B2 or B3. If its a Seacore drive then about another 1K. Add labor, pulling the boat and other stuff. Then being in Canada the cost would be more as well
https://www.mercruiserparts.com/bam/...30969/11210/20
